Revell TOS Klingon D7
Re: Revell TOS Klingon D7
Postby MSgtUSAFRet » Wed Aug 23, 2017 12:45 pm
Andy, this looks fabulous! Loving the build so far!
andyh wrote:I'm moving forward on this build now the decal is done. Starting some weathering and further panelling with chalks now.
Okay, newbie question here. Chalk? How are you using/applying it? Is it a drybrush technique where you grind the chalk into a powder, dip a dry brush into the powder and "paint" it on the model? How does it stay put?
If you wouldn't mind laying out the technique or provide a link to someone explaining the technique, I would greatly appreciate it! THX!
Keep going! Learning lots!
andyh
Postby andyh » Wed Aug 23, 2017 7:26 pm
Exactly right Steve. They technique is just that. All I'd add, is that you have to mask the line you want done and most of the brushing on of chalk is actually done onto the masking tape at the very edge. Only a little goes on the model itself. Make sure to blow or lightly brush off the excess powder with a clean wide brush (in the direction that you wish it to fade).
They are an oil based chalk used by artists so the powder "stains" the paint.
A clear coat makes it permanent :)
Andy
Postby trekriffic » Wed Aug 23, 2017 8:13 pm
Chalks can add a whole other layer of realism to a model. I used them extensively on my Klingon Bird-of-Prey model to add weathering and staining giving the model that "used and abused" look.
Before:
After:
Postby MSgtUSAFRet » Thu Aug 24, 2017 12:15 pm
Thanks, Guys, for the low down on the Chalk/Dry brush technique as well as the examples!
I hadn't heard of the oil based chalk so that and the clear coat really cinches it up for me.
Apologies, Andy, for hijacking the thread.
I now return you to your regularly scheduled programming! :)
Users browsing this forum: No registered users and 35 guests
