1/350 Refit Enterprise Deflector Dish Removal
Ncc1701Fabe
Postby Ncc1701Fabe » Tue Jun 28, 2016 4:29 am
Hello All,
Need some help. I purchased a fully assembled partially lit 1/350 Refit Enterprise that was screaming for help. And noticed that the deflector dish was placed and glued backwards. So the "bowl" side is facing out rather than in the hull.
Is there anyway of removing this piece without damaging the surrounding area. Is there some sort of solution or solvent that can be placed as best a possible around the dish to possible loosen it up?
Or if anyone has any other solutions, that would be great!
Thanks
Re: 1/350 Refit Enterprise Deflector Dish Removal
Postby andyh » Tue Jun 28, 2016 9:12 am
I heard somewhere that you can freeze Superglue to get parts apart but not sure how you would go with it. It looks like you will need to get the whole deflector dish shroud part off to try and get the dish out of it.
Postby Moongrim » Tue Jun 28, 2016 1:06 pm
For superglue- they make an "un-cure":
But it too comes with problems. It will uncure the cya, but it will also affect the surrounding plastic (soften it). Frankly I'd be stumped attempting to 'fix' this.
Postby DefiantClient » Tue Jun 28, 2016 2:07 pm
I'd say, try to brush some Simple Green along the edges of the dish like a wash. You may need to apply multiple times. The only issue is the simple green possibly leaking inside the model and damaging the electronics. I don't think it will, depending how you do it. It will also strip the paint, but there will be no damage to the plastic.
Postby NCC1966 » Tue Jun 28, 2016 3:08 pm
LoL, this backward deflector made the main hull looks like an old jet engine.
:lol:
patrickivan
Postby patrickivan » Tue Jun 28, 2016 4:27 pm
screw it and own it! New style deflector installed for a short trial period.
It was damaged during one of the Enterprise's many many many many encounters with space anomalies, then it was replaced with the original.
"I drink to make people interesting"
George Nathan
Postby Cubey Terra » Tue Jun 28, 2016 7:06 pm
Patrickivan has the best solution. It's a good looking build, and it would be a shame to damage it.
But if it were mine, and I really really wanted to fix it, I'd buy a new deflector part and replace it. Break, cut, and/or drill it out leaving the round inner bezel. Glue some styrene bits to form a bit of shelf around the edges, then drop the new deflector in. Putty and paint. You could do the whole thing without touching the outer hull paint.
Hossfly72
Postby Hossfly72 » Tue Jun 28, 2016 7:27 pm
You could drill a hole in the center, stick a post in it, and mount an old style dish.. Call it an in between upgrade.
Postby NCC1966 » Wed Jun 29, 2016 12:51 am
Lots of great ideas!
Users browsing this forum: No registered users and 20 guests
