car colors for models?
trek3159
Postby trek3159 » Sat Jan 11, 2014 11:24 pm
Hey, guys, was wondering if rattlecan paint for cars would be safe to use on models (resin or plastic). Chevy makes a light gray that is almost white that I thought would look good on TMP era starships. Any one ever use this stuff on their models?
Max Nex
Re: car colors for models?
Postby Max Nex » Mon Jan 13, 2014 12:55 pm
do you mean rattlecans for real cars? (usually lacquer-based)
or for scale cars (usually petroleum-based)
if it is for polystyrene plastic then the answer would be yes.
Postby Tesral » Tue Jan 14, 2014 6:21 am
I've used auto colors on resin. I have not tried in on styrene, but as I don't paint without a primer i don't see it being an issue.
zookman
Postby zookman » Tue Jan 14, 2014 4:53 pm
arent some of the newer car paints acrylics . for enviromental reasons and no fumes and easy water cleanup . wonder how those would work on normal plastic kits .
Postby Steam235 » Tue Jan 14, 2014 5:11 pm
I once used krylon primer plus color. bad news. I'd stay away from anything offer extra coverage or such.
Postby Tesral » Tue Jan 14, 2014 6:05 pm
Steam235 wrote:I once used krylon primer plus color. bad news. I'd stay away from anything offer extra coverage or such.
You have to watch mixing some paint types.
Trek-Tastic
Postby Trek-Tastic » Tue Jan 21, 2014 7:19 pm
I personally use acrylic as my base color (I ALWAYS use primer) for all of my styrene kits but that's only because I found a color that works for pretty much any starship, regardless of era. It's a craft paint from Apple Barrel called Dolphin Gray. I'll post some pics of it in action later but it thins very well with either Future or Tamiya/Testor's thinner for airbrushing. I go 2:1 or 1:1 depending on what works better for the given project. Another reason why I base coat with acrylics is because I detail with enamels. When I detail with enamels, I can use mineral spirits to clean up any flubs without affecting the acrylic base.
As far as using the rattle cans of auto paint is concerned, you should test it out on sprues first. I use auto colors right from Pep Boys (Duplicolor, Krylon) for my resin prop kits and have no issues at all. That being said, I sprayed a bunch in a Solo plastic cup last night to brush on the fine details and it melted right through the bottom of the cup and I'm pretty sure those cups are styrene.
I do believe it's a different story when you use primer and I don't believe that auto primer is lacquer based (or at least it's not the same animal as the paints) because I'm pretty sure that I've used Duplicor primer on styrene kits with no problem. Again, it never hurts to test on sprues first.
curt
Postby curt » Wed Jan 22, 2014 5:52 am
Yes they can be used. However a word of caution,
1- Use the correct primer for the paint system you are using.
2- Use light coats
3- Be aware that some plastic crazzing WILL take place. ALLWAYS when using a laquer base.
4- ALWAYS Use a primer sanding sealer
Hope that helps. Let me know what paint manufacture is an I can try to help further.
Curt
Postby Steam235 » Wed Jan 22, 2014 3:04 pm
Trek-Tastic
Postby Trek-Tastic » Wed Jan 22, 2014 4:26 pm
Steam235 wrote:
Trek-Tastic wrote:I personally use acrylic as my base color (I ALWAYS use primer) for all of my styrene kits but that's only because I found a color that works for pretty much any starship, regardless of era. It's a craft paint from Apple Barrel called Dolphin Gray. I'll post some pics of it in action later .
Did I just see your work on Face book? A Nebula Farrugut? If so it looks awesome. It's a great color.
Ya did, and thanks for that! And thanks for being a member of Friends of Drex!
