How do you resolve the white decal?
Postby NCC1966 » Wed Jul 13, 2016 9:19 pm
Hi friends,
I have a couple vintage kits here (Ent TOS, Reliant, etc) and the decals are practically unusable, full of yellowish spots and worse: mold.
OK, I scanned the original sheets and remade the whole crap in Corel Draw. I bough a few sheets of decal paper (clear) but as you know we have some details with white background. Not a big problem in ships with overall white (or close to white) hull paint, but it may start to annoy in grey ships.
I could buy a white background sheet to the details, but there are small decals that may be tricky to cut.
How do you usually resolve it?
Re: How do you resolve the white decal?
Postby trekriffic » Wed Jul 13, 2016 10:46 pm
If you can't find white decal paper print the decal on transparent decal paper like usual, paint the area of the hull underneath it white using a mask made from Tamiya tape and trimmed to the size of the decal's border, let the paint dry (I use enamels), sand lightly to get rid of any paint edges,apply a gloss clearcoat, let dry, lay the decal over the top of it, then seal with another gloss clearcoat after the decal dries for a day.
Rampaging Rear Admiral (LH)
Postby MEATLOAFr » Thu Jul 14, 2016 2:53 am
way I get past it is print the wight as a silver or grey color
you can get white printed with special printers - ALPS is most well known (sold mine) but they are hard to get and can be temper-mental for the casual printer (like I am)
Postby NCC1966 » Thu Jul 14, 2016 2:29 pm
trekriffic wrote:If you can't find white decal paper print the decal on transparent decal paper like usual, paint the area of the hull underneath it white using a mask made from Tamiya tape and trimmed to the size of the decal's border, let the paint dry (I use enamels), sand lightly to get rid of any paint edges,apply a gloss clearcoat, let dry, lay the decal over the top of it, then seal with another gloss clearcoat after the decal dries for a day.
I thought of it (paint the white) but imagined that I was getting crazy. I will try this!
On a side note, let me ask you: do you use regular sandpaper or wet sandpaper? I use enamel too.
Postby trekriffic » Thu Jul 14, 2016 5:08 pm
NCC1966 wrote:On a side note, let me ask you: do you use regular sandpaper or wet sandpaper? I use enamel too.
I use the sanding films that Testors sells. I think it's the red sheet which is 600 grit. And yes to wetsanding it.
Postby NCC1966 » Thu Jul 14, 2016 7:32 pm
Thanks!
I usually use dry sandpaper for pure laziness and because the mess that wet sanding does. But I have had some problems scratching surfaces. I have to review my finishing methods.
:oops:
Users browsing this forum: No registered users and 8 guests
