Was going to be a scout, then a freighter or maybe a Tanker
Post by Kremin » Tue Jan 12, 2016 10:10 am
ok so I had an old AMT 1:650 TOS E and I wanted to do something with it, my last one got turned into a destroyed TOS PA ship
so My first thought was to make a small scout, something that could land on a planet and act as a base for survey teams to do a larger scale investion of a planet.
So first off is to cut off the lower part of the primary hull so I can get rid of the curve underneath (otherwise there wouldn't be enough height even for 1 deck and cut out a section on the top of the primary hull to fit the Bridge B/C deck recast from a 1:350 set
the original plan was to have a section built up aft of the bridge with a couple of shuttle bays and nacelle(s) above the main hull and would possibly end up looking like a bulked up Larson
ANYWAY got bored of it / didn't like how it was looking so shoved it to one side and built a different ship as I'm just about finished that (just waiting on decals) I had a couple of days and decided to pull it out and see what I could make. My first idea is a mixed use freighter 3/4 Primary hull, Nacelles underneath fuel pods attached and extra section with old style cargo pods attached (DY-100 style)
Re: Was going to be a scout, then a freighter or maybe a Tan
Post by Kremin » Tue Jan 12, 2016 10:32 am
Cut the main lower plate on the Portrait to give an inital structure to stick most of the rest of the hull to
the top of the hull will be cut to the shape of the plate giving space for twin fuel pods in the void created
there will be a cylinder added through the primary hull which at the front will house the main deflector
and at the aft will have the nacelles under the main hull
As the mounts for the nacelles are made from half the secondary hull the mounts will need to be strengthend so I used a couple of peices of spure which were also used to brace the primary hull
Aft of the nacelle mounts (where the shuttlebay doors would be) the hull will extend back and either be cargo or a tanker I haven't decided which yet
Post by Kremin » Tue Jan 12, 2016 11:02 am
Cut into the hull to see the start of the shape
and just placed the fuel pods to see how they look
Post by Moongrim » Tue Jan 12, 2016 3:04 pm
And it's starting to shape up rather nicely...
Post by Drop_Bear » Wed Jan 13, 2016 2:12 am
Looks cool!
Post by MEATLOAFr » Wed Jan 13, 2016 2:28 am
I like it, please continue
Post by trekriffic » Wed Jan 13, 2016 4:55 am
Looking forward to seeing how this develops.
Post by Kremin » Fri Jan 15, 2016 12:19 pm
Decided she's going to be a tanker so the pods are just going to be too small
spare parts stash raided and I have something bigger
Two of these should go nicely
Post by Kremin » Sun Jan 17, 2016 1:10 pm
Topside structure progressing and put the fuel pods next to it to see the size
Underside mostly done giving the nacelles a try in their position
the engineering section lots of chopped up bits smoothed together
And I need to add something in here
Post by Kremin » Sun Jan 17, 2016 1:41 pm
Two tools I couldn't do without are
Hand held battery Dremel with rotary cutting tool and sanding drum
while you can get and I have a mains operated one I like to portability and lower speed of this for cutting any material
and Digital calipers measuring inside outside or depth
self evident for measuring, great for finding sizes of stuff for cutting.
Silhouette Portrait
most of the time when I'm cutting sheet streen I now do it on my Silhouette Portrait machine as my hand is nowhere near steady enough to cut anymore
http://www.silhouetteportrait.co.uk/
It can be used on paper, card, fabrics, vinyl, and thin plastic although I use a different blade depending on what I'm cutting. I can cut upto 0.75mm plastic using scribe and snap thinner plastic can cut right through
It's also great for cutting frisket paper used in making paint masks for Aztecs in any scale and possibly registration numers etc (but I'm still working out the best settings to use)
