1/350 Reliant.
1/350 Reliant.
Post by andyh » Sun Aug 14, 2016 2:56 pm
I decided to make a start on my 1/350 scale Reliant conversion kit. It looks very daunting as I'd like to light this up. One of my biggest hurdles will be working out what to do with the shuttle bay surround lighting as the kit is cast in opaque resin.
I might have to ponder on it, but I can see that I'll probably have to cut the whole back panel out and try and redo it in clear resin. Not looking forward to that!
Re: 1/350 Reliant.
Post by Kremin » Sun Aug 14, 2016 5:14 pm
Got the same kit and the same problem, almost too scared to start on it
Re: 1/350 Reliant.
Post by Moongrim » Sun Aug 14, 2016 10:02 pm
So I take it that the kit (rear of the Primary Hull) doesn't come hollow?
Re: 1/350 Reliant.
Post by andyh » Mon Aug 15, 2016 3:52 am
yes, it's hollow, but you cant cut out the slots around the shuttle bay doors because of the need for a right angled drill :)
Re: 1/350 Reliant.
Post by Moongrim » Mon Aug 15, 2016 1:25 pm
Re: 1/350 Reliant.
Post by Kremin » Mon Aug 15, 2016 1:28 pm
You should see what the guy from Aztek Dummy has done to his lol
Re: 1/350 Reliant.
Post by andyh » Mon Aug 15, 2016 1:42 pm
Moongrin, LOL, that might work if it was about 20 times smaller to fit inside the shurttle bay opening :)
Kremin, have you got a link to his build?
Re: 1/350 Reliant.
Post by Kremin » Mon Aug 15, 2016 1:49 pm
Sent you a PM there is also a nice shuttlebay doing the rounds on Facebook but don't know if it'll fit
https://www.facebook.com/groups/9536367 ... 044405121/
Re: 1/350 Reliant.
Post by Kremin » Mon Aug 15, 2016 3:20 pm
looking at the front end of the blockhouse there are a couple of different methods being tried to attach it at the hull 1 cut the segments just behind the grid line so leave the front of the add on part intact or cut the add on part across where it meets the hull and mount it on top
I don't know which way I will do mine yet but I am leaning towards mounting on top, just for strengh of the joint
Re: 1/350 Reliant.
Post by trekriffic » Mon Aug 15, 2016 3:58 pm
Moongrim wrote:???
You might have a problem with clearance with that Moongrim. Don't see how you get that head into a 1/350 Reliant shuttle bay opening.
andyh,
You are you talking about the lit slots around the doors right?
