Building Stands for Resin Kits
A place for those new to the hobby (or at a basic skill level) to ask questions and hone their skills.
SKO
Postby SKO » Sun Jul 16, 2017 9:50 pm
I built my first starcraft kit and now she needs a stand. Where do you get the rods? Do you just use a drill to create a hole in the kit?
Re: Building Stands for Resin Kits
Postby mophius » Sun Jul 16, 2017 10:48 pm
I purchased a whole load of acrylic rod, 4 or 5mm, and also some brass rods of the same size.
Resin kits are good to drill into just pick a thick section or where you think will take the weight. Taking into account the point of balance.
Plastic kits need a bit of meat inside the kit to drill into. You can put some modelling clay or something similar inside while building up.
SKO
Postby SKO » Sun Jul 16, 2017 11:50 pm
mophius wrote:I purchased a whole load of acrylic rod, 4 or 5mm, and also some brass rods of the same size.
Can you get that at hardware stores or craft stores?
Postby Tesral » Mon Jul 17, 2017 4:04 am
My standard stand is a 3/32" brass rod in a 1/4" plexiglass base.
Yes, you drill a hole in the bottom of the model if you want to display it on a rod. That is usually one of the first things I do is drill the hole.
SKO
Postby SKO » Wed Jul 19, 2017 12:51 am
Thanks gang. She is properly mounted and part of the fleet now
Return to “Newbie Modeler Help Desk”
Users browsing this forum: No registered users and 3 guests
