D-7M K'T'Inga, IKS veS qa' - Spirit of War
Post by Griffworks » Sun Aug 27, 2017 8:51 pm
This is the 1/1000 scale K'T'Inga-class battlecruiser resin kit from UGH! Models. The master for this kit was made by Matt Meyers and first produced by Jupiter Station and sold thru Starship Modeler for several years, then sold by Delta Quadrant for about 4 years, now UGH! has it.
The kit is cast in blue resin - an unofficial trademark of UGH! Models. It comes in 10 pieces, plus a basic Klingon Trefoil base. Once assembled, it's 9.25" / 24cm long by 7" / 17.8cm wide.
I used Rustoleum primer once the model was assembled, then cleaned up seams using Tamiya Putty Basic Type, which I call Tamiya Grey due to its color. The base coat is Tamiya rattlecan AS-14 OD Green (USAF).
The name veS qa' in Klingon means Spirit of War in Federation English / Standard.
I have no illusions about this being as nice or accurate a build as Trekkrific's. I'm just here to have some fun, anyhow, and bolster the Imperial Klingon Fleet!
The command decks section. I forgot to take a pic of all the pieces/parts.
All assembled.
Set on an older base from when Delta Quadrant sold the kit, which is the same as the old Jupiter Station runs of the kit.
Pour stub that needed removing.
After use of a nice, extra sharp Xacto blade and all gone!
First coat of the base color, Tamiya rattlecan AS-14 OD Green (USAF). It turned out a little darker than I had hoped.
He's got several coats on him now, and detail painting has started. And, as always, more to come.
Re: D-7M K'T'Inga, IKS veS qa' - Spirit of War
Post by el gato » Fri Sep 01, 2017 7:09 pm
:thumbsup:!
Post by trekriffic » Fri Sep 01, 2017 10:33 pm
Nice work so far Jeff. This was such a fun build. Even without all the mods I made this will turn into a nice rendition of the "real" thing. Do you plan on doing any weathering with chalks?
Post by Griffworks » Fri Sep 29, 2017 1:31 pm
Forgot to update this from a couple weeks back.
Panel details hand painted.
trekriffic wrote:Nice work so far Jeff. This was such a fun build. Even without all the mods I made this will turn into a nice rendition of the "real" thing. Do you plan on doing any weathering with chalks?
Sorry, I thought that I had replied to this. I suspect that a reply was typed out, then something happened which distracted me....
I've never used chalks, so likely won't here. Not sure how I'll end up weathering him. I'm sure I'll come up with something, obviously.
