FASA Orion Wanderer Blockade Runner
Post by Griffworks » Thu Sep 21, 2017 1:38 am
I purchased this off of Shapeways and it arrived yesterday.
https://www.shapeways.com/product/3ASS2 ... d=63088875
It required a BUNCH of sanding on the forward hull perimeter because of how the original model was designed. I've sanded, primed, sanded, and primed one more time, specifically working on the forward hull, the two underslung pods, and the warp nacelles, trying to take the angular sections out of the equation. So far, I'm mostly happy with it.
The model is roughly 7.75" / 19.7cm long, by 2.5" / 65cm wide. It was printed in WSFP (White, Strong, Flexible, and Polished). The model surface is still rough in several areas, tho the sanding and Tamiya Surface Primer has taken most of that out of it. Still a little more sanding needed, but I'm done with that for the day. Having a couple drinks in honor of the passing of a friend. :(
Basic angle shots of the "raw" model.
Giving us an idea of the length and width.
Sand, prime, sand, prime... You can see how I got the angles down on the forward hull, as well as the two pods below. I've also softened the angles on the extended hull. I think I'll keep them like that.
More to come.
Re: FASA Orion Wanderer Blockade Runner
Post by el gato » Sun Sep 24, 2017 3:54 am
Your Dremel is still working after you sanded that down? Wow
Post by Tesral » Sun Sep 24, 2017 6:27 am
el gato wrote:Your Dremel is still working after you sanded that down? Wow
No word on sanding drum casualties however.
Post by Kremin » Sun Sep 24, 2017 7:40 am
awesome work, awaiting progress
Post by el gato » Sun Sep 24, 2017 9:24 pm
True. Griff's lack of cussing gives me hope there were survivors
Post by Griffworks » Sun Sep 24, 2017 11:18 pm
Ha! You guys are hilarious! :lol:
I did not use the Dremel. That would've been too easy, and I'm a masochist! So, I hand sanded the whole thing. It gives better control, plus there were some tight spaces needing to be gotten to.
Priming and sanding is done. Now I just have to suss out what color(s) to go with. I'm kinda leaning towards maybe platinum as the base. Something a little different.
I took these to give a better idea of the overall size of the model next to a Constitution-class model - built by my youngest son.
Post by el gato » Tue Sep 26, 2017 3:15 pm
Hand sanded WSF? I did that for hours one day and only made a small dent. What grit of sandpaper were you using? One?
Post by Griffworks » Tue Sep 26, 2017 5:18 pm
The first three times I used 220, then the last was 600.
Post by el gato » Tue Sep 26, 2017 6:15 pm
:o I've used 100 and nothing. nothing noooootttthhhhhiiiinnnngggg....
Post by Tesral » Tue Sep 26, 2017 11:25 pm
el gato wrote::o I've used 100 and nothing. nothing noooootttthhhhhiiiinnnngggg....
He must have true grit.
