From UGH! Models, this is their 1/1000 scale kit, formally sold by The Delta Quadrant. It's a pretty straight forward kit, containing 6 parts, a Klingon Trefoil base, very comprehensive decals that include panels, and a pretty comprehensive decal sheet. Once assembled, the model is about 8.5" / 21.5cm long.
Pieces/parts!
Next to the Miscellaneous Models D-10 Heavy Cruiser.
I primed him using Rustoleum Primer for Automobiles, then the base coat is Tamiya rattlecan TS-20 Metallic Green. It was sort of a test to see how it would look on a Klingon Ship. I sorta like it, tho because I think once I hit it with Dullcote that it'll look a lot better. Then I'll dirty it up!
I'll add more info a bit later.
Klingon D-4 Battlecruiser
- Griffworks
- Can-Do Captain
- MSgtUSAFRet
- Can-Do Captain
Re: Klingon D-4 Battlecruiser
Nice, Griffworks!
I love the cut outs!
Would love to see what you do with it!
- Legendary LT Commander
Ho ho, nice build!
Wait, now ... that D-10 wouldn't be the one from Fasa's Trek RPG, would it be?
(With apologies to Tesral for nicking his sig. )
- mophius
- Crafty Captain
The D-10 is still available in 1/1000 from FedMods. Check it out under Miscellaneous Models
EDIT. just seen that Griff put it was from MM lol $55 is not bad for all that resin
- el gato
- Fatidical Fleet Admiral
Are you going to add all of those bracing wires? I need to add the aft ones to my 2500 version
- Griffworks
- Can-Do Captain
I intend to, yes. I'm going to use either some brass rod/tube or plastic rod/tube. Haven't fully decided just yet.
