Alternate Paradigms Shapeways Shop
Alternate Paradigms
Post by Alternate Paradigms » Sun May 06, 2018 11:09 pm
Since the announcement of the various parts I have available through the Shapeways shop are spread over multiple threads, I figured I should take my cue from Crazy Eddie and create a single thread to highlight what is there.
Constitution Mark III Star Trek
As you know, Brian Pimenta created what Del & I are calling the "Constitution Mk III" ship. Brian designed his Enterprise soon after seeing ST III and speculated what the next version of the iconic ship would look like. I created two other variants using Brian's design elements. You can always pick up the 3 currently available kits through Multiverse Models. Thanks to a couple of suggestions from mophius, I have expanded the number of parts that can be used with your Connie Mk III universe of ships. Add to your fleet with these:
Saladin-style scout
Dreadnought-style battleship
Shorter neck
Over nacelle, to be used with an MVM MK IIIverse kit or with a 2500 Cadet Refit, on its own or in conjunction with the Mk IIIverse-style Alternate Engines #2
Under nacelle, to be used with an MVM Mk IIIverse kit or with a 2500 Cadet Refit, on its own or in conjunction with the Mk IIIverse-style Alternate Engines #2
Coming soon: Sensor pods for a second type of science cruiser...
Alternate Engines
These were created to add a little variation to your 2500 Cadet ships. These should plug right into your AMT kits
Alternate Engines 1 - 2500 Scale - The sides of these nacelles are parallel to each other
Alternate Engines 2 - 2500 Scale - The sides of these nacelles have a slight taper towards the back and are similar to those of the MVM kits
Alternate Engines 3 - 2500 Scale- These nacelles have a slight bulge in the middle when viewed from the front
Alternate Engines 4 - 2500 Scale - These are offered with the approval of Bill Krause
Coming soon: Alternate engines for your Romulan and Klingon ships...
Let history never forget the name... Enterprise
CVN 65 in 2500... because. The CVN 65 is also offered in other scales, including 1800, 2400 and 3000. Check out my SW shop for those.
Timey Wimey
The 9th and 10th Doctors' TARDIS is offered in various scales (72, 48 35 and 32). Check out the shop for those.
Coming soon: The First Doctor's TARDIS as well as the 11th and 12th Doctors' TARDIS
Re: Alternate Paradigms Shapeways Shop
Post by mophius » Fri May 11, 2018 5:49 pm
Parts shipped today so I should see them on Monday. When I have the parts to hand I will decide which ships I want to purchase off Del and place the order.
Post by mophius » Wed May 16, 2018 1:56 pm
Here they are.
First up is Dreadnought conversion. Impulse engine is at the end of the nacelle
Saladin Conversion
Connie3 lowered neck
And finally the Sentinel type nacelles
I really should put some colour on them so you can see all the details.
Post by mophius » Wed May 16, 2018 5:44 pm
I didn't see on your first post that you are doing a new type of sensor pod. I have got a Northtrek one here I am looking at working into a version somehow or I have the two from the Kaydee kit.
So far I have
  • Saladin class
    Dreadnought class
    Light cruiser class - in progress
    Akula class
    J Edgar class
And then some that will take a little bit of work to get right.
  • Hutzel class
    Oberth class
    Constellation class
    Peregrine class
    Nelson class
    Renaissance class - may look odd with the nacelles sideways
Post by mophius » Wed May 16, 2018 10:52 pm
Some quick-fit pics.
Saladin
Akula
J Edgar
Nelson
Dreadnought
Hutzel
and a new one tonight - Saipan class
I don't have a Kaydee neck and secondary hull to hand and think at least the Hutzel would look better with the shorter closer secondary.
Post by mophius » Wed Jun 13, 2018 3:24 pm
Saladin version all finished, and sorry to my followers as I have not posted updates on this one yet.
RL is a pig sometimes.
