Intrepid class Refit
dJiPi
Post by dJiPi » Wed Mar 28, 2018 11:17 am
With the release of the R.M. Voyager (Intrepid Class) I have decided to built my O.S. kit as an Intrepid Refit.
I hope I will be able to correctly fit the warp nacelles and align them .... (MVM kit)
I will have to source a more modern bridge module (that’s why I would like somebody to release bridge modules from various eras, a sovereign type would be nice ;-)
dJiPi the froggy
dJiPi
Re: Intrepid class Refit
Post by dJiPi » Wed Mar 28, 2018 1:54 pm
Glued the pylons (warp nacelles are just dry fitted)
next step: pour as much as possible Zap-a-gap to strengthen the fitting,
then .... sanding the connection !
dJiPi the froggy
Post by mophius » Wed Mar 28, 2018 2:47 pm
I like that but maybe with slightly shorter pylons. Maybe so the nacelles are level with the sides of the saucer.
dJiPi
Post by dJiPi » Wed Mar 28, 2018 2:58 pm
The warp nacelles should be, I hope ;-), just above the saucer so the bussard collectors are not masked by the saucer.
I will have to source and add some impulse drives as well, I would like to fit them on the saucer (and not on the pylons) but their exhausts might be on the way of the pylons, still thinking about it...
dJiPi the froggy
Post by Tesral » Wed Mar 28, 2018 3:36 pm
I would get rid of the straight section by the hull since you are adding impulse engines. The pylons look "tacked on", they don't flow. I would go for a clean angle from the hull, and move them forward a bit. But that's me.
I think the intrepid is a nice looking hull, but size 8 ship size 5 nacelles.
Post by el gato » Wed Mar 28, 2018 6:41 pm
I like this idea. It'll be something for me to consider if the Intrepid I have for sale doesn't sell.
As for getting a more "modern" bridge, a trick RogueWolf and other kitbashers like to do is to use is to cut out the bridge module from another model and use it here. If you don't want to go down that road, look at your spare parts and see if there's a cap you can use that sort of fits the era. If that doesn't work either, then make a mold of the Intrepid bridge and cast your own
dJiPi
Post by dJiPi » Wed Mar 28, 2018 7:05 pm
Hi E.G.,
I have 2 sovereign waiting for kit bashing, I think I’ll cut out the bridge module from one of them (and maybe the impulse drives) then re-cast these parts but I need to find/order silicone and resin from à French supplier ....
dJiPi the froggy
Resin-Modeller
Post by Resin-Modeller » Wed Mar 28, 2018 7:16 pm
A good trick I found when wanting to clone a part, is use modelling clay like plastersine to make a non residual mould, and then use soft clay (or resin) to fill it.
Presto, cloned part, saves destroying models or harvesting parts although they will need a clean up and potential patching if you get air bubbles whilst doing it.
Adam,
RESIN MODELLER
Post by el gato » Wed Mar 28, 2018 7:47 pm
dJiPi wrote:Hi E.G.,
Resin-Modeller wrote:A good trick I found when wanting to clone a part, is use modelling clay like plastersine to make a non residual mould, and then use soft clay (or resin) to fill it.
Adam,
Borrowing from Adam/Resin Modeller's post, I sometimes use Aves putty if I don't want to mix up a batch of resin. Also, if you don't want to cut out the bridge module and you're not going to use the captain's yacht part, I know a certain modeler who likes to use the yacht as a bridge module:
Post by Tesral » Wed Mar 28, 2018 9:31 pm
Adam,
I do this when needed. One does not need to mix a huge batch of resin. I've done eyedroppers full..
