Questions about the AA Enterprise 1701-A
All figures, Ships and Accessories.
Laforge
Postby Laforge » Mon Sep 26, 2016 4:32 pm
1) I would like to replace the ship markings with more accurate ones (registries, etc.), what is the best solution or paint to remove the current markings on the ship without damaging the plastic?
2) I want to repaint the Blue Deflector as the color on it is fading.
Re: Questions about the AA Enterprise 1701-A
Postby Moongrim » Tue Sep 27, 2016 1:34 pm
Laforge wrote:1) I would like to replace the ship markings with more accurate ones (registries, etc.), what is the best solution or paint to remove the current markings on the ship without damaging the plastic?
Immersing the model into a bucket filled with a 1:1 solution of Simple Green and water.
http://www.dakkadakka.com/wiki/en/WarOn ... ing_Method
Postby trekriffic » Wed Sep 28, 2016 3:45 pm
Walmart carries this stuff and it will take off enamel and chrome in a few hours:
Super Clean Spray Bottle.JPG (12.83 KiB) Viewed 2888 times
I've heard Easy-Off works too but never tried it on models.
Do you know what kind of paint they use on those AA toys? If its lacquer that can be tough to remove.
Postby DefiantClient » Wed Sep 28, 2016 7:19 pm
As much as I recommend Simple Green to strip paint, this will kill all the electronics inside. Using a spray bottle solution like Trekriffic suggested may be a better idea.
Postby Moongrim » Thu Sep 29, 2016 1:27 pm
He didn't say anything about keeping the electronics inside working.
But simple green can also be applied externally...Just soak it into some paper towels and let it hang.
Laforge
Postby Laforge » Sun Oct 02, 2016 1:51 am
Moongrim wrote:He didn't say anything about keeping the electronics inside working.
Thank you, I will try that as the purpose is for use externally. The electronics are still working great after all these years.
pengbuzz
Postby pengbuzz » Fri Feb 24, 2017 4:19 am
Also, try 91% rubbing alcohol.
Return to “Action figures and Toy Ships”
Users browsing this forum: No registered users and 9 guests
